Welcome to the forum. I'd have to sure the battery has a full charge and the battery connections are good, not only check connections at the battery, check the other end of those connections. If that checks out, I check the circuits at the starter relay. Just unplug the relay, use a testlite, have a helper turn the key to crank, how many hot terminals, should be two. Any testing make sure the tranny is in park or neutral and the e-brake is set.
Sep 15, 2009 at 9:00 AM
