I have a no start problem. I was driving around 65mph and it just died on me no warning no nothing just died. I have fuel and i have spark. I changed the oil cause it was full of fuel. Changed the plugs and fuel filter. I pulled the fuel relay out and it ran for a second or two i put the fuel relay back in and it wont run. I sprayed starting fluid in it and it did nothing with the fuel relay in if i pull the fuel relay back out and spray starting fluid in it the car will run real ruff. I changed the map sensor too and it seemed like it wanted to start but it wont. There are no codes coming up for anything. Dose anyone have any ideas im at a loss and i need my car back for monday so i can get to work. Could there be a timing problem? I dont think so because it has a chain and not a belt.
Oct 16, 2010 at 6:55 PM
