2002 Chevy Cavalier No electrical power battery is good.
2002 CHEVROLET CAVALIER
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
GPETZEV
When I tried to start my Chevy this morning it was like there is no electrical power at all. Then from time to time the meters on the dashboard would go in the oposite direction for short time without the key being on the ignition at all. There is a good spark from the battery and I already tried jump start - nothing. Even the clock is off. Turning the ingition key has no effect whatsoever.
Feb 2, 2008 at 5:21 AM
DAVE29
Did you check the connections at the battery make sure they are tight? Check your fuses, make sure they're all good.
Feb 2, 2008 at 6:36 AM
