2002 Chevy Cavalier no dash lights/or dome light working
97,777 MILES • 4 CYL • FWD • AUTOMATIC
LMARIE
changed battery and spark plugs 3 dayys ago the next morning got in my car dome light not working and no dash lights all other lights work radio ,blinkers,heat,air outside running lightsall work ,had all fusses checked at auto zone all good.the guy at auto zone said maybe the bulb in the dash blew can that be the problem?
Sep 2, 2009 at 2:05 PM
JDL
  • 16,098 POSTS
Are you talking about instrument illumination or warning lights, these maybe separate circuits. Did the person check for voltage at the fuse circuit, even if the fuse is good, if there is no voltage, the circuit is dead. Did the person check for any possible codes?
Sep 3, 2009 at 2:30 AM
LMARIE
did not check for codes, the lights not working are the dash lights where the spedomoter is and rpm dial and the dome light i thought it was the drl relay? is that a fuse i can buy and put in or not.
Sep 3, 2009 at 7:15 AM
JDL
  • 16,098 POSTS
Do you have a dimmer control for the dash lites, you might try turning that, see if the dash lites come back? Also, check the radio/ interior lamp fuse 10amp, use a testlite the fuse circuit should be hot all the time.
Sep 3, 2009 at 7:47 AM
LMARIE
yes i have a dimmer switch i tried that no luck but i will try checking the 10amp fuse with a testlite i will let u know thank u for ur time
Sep 3, 2009 at 10:06 AM
