2002 Chevy Cavalier ignition switch
TGRANT0124
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • MANUAL
  • 160,000 MILES
How do you replace the ignition switch in an 02 cavalier?
Thursday, July 22nd, 2010 AT 9:49 PM
Ignition Switch Replacement - On Vehicle
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Service Precautions.
Disconnect the negative battery cable.
Remove the steering column trim covers.
Remove the ignition lock cylinder.
https://www.2carpros.com/forum/automotive_pictures/12900_i_3.gif
Remove the retaining screws (2) from the ignition switch (3).
Remove the ignition switch (3) from the steering column (1).
Installation Procedure
Install the ignition switch (3) to the steering column (1). Notice: Refer to Fastener Notice in Service Precaution.
Install the retaining screws (2) to the ignition switch (3). Tighten the screws to 4 Nm (36 inch lbs.).
Install the ignition lock cylinder.
Install the steering column trim covers.
Connect the negative battery cable.
Monday, March 22nd, 2021 AT 5:52 PM
