reset computer and clear codes?
212,000 MILES • 4 CYL • AUTOMATIC
MUSTANG67MH
  • 11 POSTS
How do I reset the cars computer? 2002 chevey cavalier. and where is the speed sensor located ?(for the odmeter? Thanks
May 17, 2011 at 12:26 PM
WRENCHTECH
  • 20,758 POSTS
This video shows the job being done on a similar car but the process is the same.
https://youtu.be/ahK_eucFi-k
The speed sensor is in the transaxle output housing.
May 17, 2011 at 1:11 PM
MUSTANG67MH
  • 11 POSTS
Thanks. I reset the service light.
May 17, 2011 at 5:08 PM
SHANNONMILLSON
how do i reset the computer?
Jun 14, 2021 at 2:57 AM (Merged)
MERLIN2021
  • 17,250 POSTS
First, read the codes, then fix the problem, light will go out, if you reset it with a scan tool, without fixing it, the light will return! Go to this guide
CMOARD
My daughter recently changed the starter and the solinoid in her car. since then when she starts it up the lights on dash ( theft system, abs, airbag,seatbelt check engine etc.) continually flash on and off.
RHALL77
  • 3,361 POSTS
It sounds like the got the wires wrong but here is how to reset the computer
LOWELL0866
What is the process for resetting the computer after it has been replaced?
BMRFIXIT
  • 19,053 POSTS
Here is the computer learning process they is no scanner style of reprogramming.
You can clear the codes before you begin though. Here is a video
VEHICLE DRIVEABILITY RELEARN PROCEDURE
General Motors does not provide a specific procedure for driveability relearn. If a vehicle battery was disconnected for facilitating repairs or a Powertrain Control Module (PCM) was replaced, driving the vehicle will enable the PCM to relearn driveability. Inform your customer that he/she may experience driveability different from what they are accustomed to until the PCM completes it's relearn function.
Cheers,
