My horn doesn't work -where do I start to look for the problem
May 8, 2010 at 4:28 AM
BLUELIGHTNIN6
✓Experienced Mechanic
start with testing the horn fuse and horn relay. if both OK test the horn itself to see if its any good. if it is then check wiring to the horn and the horn switch pad on steering wheel.
May 8, 2010 at 5:26 AM
