2002 Chevy Cavalier head lights
OUTDOORSMAN
Electrical problem
2002 Chevy Cavalier 6 cyl Two Wheel Drive Automatic
just replace lights/turn signal switch again, as it went bad again.Now when i try to switch on low beams, they blink a few times then go out, high beams work, turns work, running lights work, but not low beams.....
Mar 21, 2010 at 8:43 AM
RHALL77
  • 3,361 POSTS
check the grounds and splices in the front of the vehicle. there is a good possibility there is corrision on those connections that need to be cleaned or replaced.
Mar 22, 2010 at 1:38 AM
