head bolt torque
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRAGONMIST1034
im replacing my head gasket i am needing to know the tork on the head bolts
Sep 17, 2010 at 11:49 AM
MADMIKE1735
  • 951 POSTS
doesnt specify if these are torque to yield, i recommend replacing them either way... this is the specs on torque
Cylinder Head Bolts-Long
First pass 63 Nm (46 ft lb)
Second pass 90°
Cylinder Head Bolts-Short
First pass 58 Nm (43 ft lb)
Second pass 90°
Sep 17, 2010 at 12:11 PM
MADMIKE1735
  • 951 POSTS
also, torque from the center outwards... start with the middle, and work your way torwards both ends evenly...
Sep 17, 2010 at 12:13 PM
AEF43
I recently asked for the torque ratio and sequence for the cylinder head bolts on a 1997 chevrolet cavalier 4 cylinder 2.2 liter engine. I did recieve the info but is that the sequence if i am standing right in front of the car looking at the head. I don't want to do it upside down if you know what i mean. Thank You!
Mar 27, 2020 at 5:40 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
hit replay to question so you keep all in one place
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_699.jpg
2CP-ARCHIVES
  • 4,540 POSTS
can i reuse head bolts.
Mar 27, 2020 at 5:41 AM (Merged)
no, they are tty or torque to yields.
replace with new
JAY4CARS1
  • 34 POSTS
ALWAYS replace the head bolts.....
AEF43
I need the torque ration on the 10 cylinder head bolts on the vehicle specified above will you please help. Thank You!
TOOOMANYTOYS
  • 513 POSTS
Tighten bolt 1 to 63 Nm (46 ft. lbs.) . Tighten bolt 2 to58 Nm (43 ft. lbs.) . Tighten bolt 3 to 58 Nm (43 ft. lbs.) . Tighten bolt 4 to 63 Nm (46 ft. lbs.) . Tighten bolt 5 to63 Nm (46 ft. lbs.) . Tighten bolt 6 to58 Nm (43 ft. lbs.) . Tighten bolt 7 to58 Nm (43 ft. lbs.) . Tighten bolt 8 to 63 Nm (46 ft. lbs.) . Tighten bolt 9 to63 Nm (46 ft. lbs.) . Tighten bolt 10 (stud bolt) to 58 Nm (43 ft. lbs.) . Use a torque angle meter and tighten all the cylinder head bolts an additional 90 ° in sequence
https://images.2carpros.com/forum/automotive_pictures/462613_head_1.jpg
LEARNINGEVERYDAY
Hello!
Apparently the 95 2.2 L aluminum engine head was poorly designed causing a more often than not coolant leak; usually from the driver side, front corner of the head.
Over the year that I have owned it; the head gasket has leaked from the driver side, front corner of the head, about a teaspoon per day. Research would tell anyone to not buy this vehicle-but since I received it as a gift I don’t mind putting some money into it. The vehicle has 50,000 Km, and still smells new inside.
Today though I noticed something new, while revving the motor a little there are what looks like air bubbles coming from the leak, along with the usual few drops of coolant.
I plan to change the head gasget myself, but until I do, would tightening the one external corner head bolt or all five external head bolts 1 mm (or to the specified torque?) help in stopping the leak? I am weary of this, for many obvious reasons.
I sicerely thank you for any responses.
BLACKOP555
  • 10,386 POSTS
tightening down may help but the gasket is shot and the amount it will help will be hardly noticable.
put on a new gasket.
dont torque down that corner or youll warp the heads and no amoutn of gaskets will help.
LEARNINGEVERYDAY
Thank you Blackop555 for your fast response!
I appreciate my free question. If and when I use this site again I will be happy to give a donation.
BLACKOP555
  • 10,386 POSTS
glad to help.
have a great day and i hope you dont hesitate to post back if you ever have another problem.
DANDINKINS
  • 7 POSTS
Just to let you know I bought a '95 brand new had the head gasket replaced under recall at 100,000 miles at 387,000 the head gasket still leaks, I just clean out the sparkplug about once a month put fresh antifreeze in an good to go.
TIGRILLO1
Engine Mechanical problem
1993 Chevy Cavalier 4 cyl All Wheel Drive Automatic
I have a '93 Chevrolet Cavalier 2 doors. But the cylinder head, i don't know how much pressure do the bolts have to have
BLACKOP555
  • 10,386 POSTS
check out your 02 sensors if you getting bad gas mileage by the way. when antifreeze burns in the exhaust it leaves a coating on the o2 sensors causing them to read lean, and resulting in the computer throwing more gas in the mixture to comphensate.
  • 31,937 POSTS
Hi there, See pics for torques & sequence. mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_53.jpg
https://images.2carpros.com/forum/automotive_pictures/61395_torques_1.jpg
BLACKOP555
  • 10,386 POSTS
DANDINKINS
  • 7 POSTS
Mine just leaks on the outside of the engine but i have replaced the 02 sensers. Right now I need to replace two fuel injectors so i am not getting very good milleage, but normally I will be around 32 mpg in town 34-37 on the hwy. I dont care what anybody says this has been a great little car it is showing it milleage a bit but would not be afraid to drive it anywhere. I drive it for work now between 600 and 700 miles a week.
BLACKOP555
  • 10,386 POSTS
good thing its leaking on the outside, that should affect performance at all!
AKTERRY
I'm replacing the cylinder head on a 2000 chevy cavalier 2.2l. I've ordered a chilton's manual but did not arrive in mail yet & today is Sun. I need to know head torque, valve settings, & pattern. Thanks.
Jun 23, 2020 at 7:24 AM (Merged)
BRUCE HUNT
  • 3,754 POSTS
Purge the system of air. Bleed it to remove the air from the system. It is possible that you have a leak in the system. The system is a closed one and thus should be coolant only and no air. I leak can reduce the pressure that the system is designed to maintain and that reduction of pressure can cause temp problems.
