2002 Chevy Cavalier grinding noise in rear end
WEIGOLDY
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 91,000 MILES
My right rear end is making a grinding noise. I think it;s the wheel bearings. Maybe axle bearings? It gets worse when I slow down or turn. Less at higher speeds.
How long can I drive like this? I only drive about 20 -25 miles per day.
Friday, September 19th, 2008 AT 12:05 AM
MMPRINCE4000
  • 8,548 POSTS
Check the bearings by raising the rear, putting on jackstands. Grasp the rear wheel and pull/push both vertically and horizontally, if there is any movement then it is probably a bearing.
Also check the brakes, and do not drive it with this condition, there are many things that can happen, none of which are good.
Sunday, September 21st, 2008 AT 7:41 AM
WEIGOLDY
Thanks for the reply.
I took it to the shop that had just done my brakes.
They found a spring had popped out and they just replacd it! NO CHARGE!
Sunday, September 21st, 2008 AT 9:00 AM
