2002 Chevy Cavalier Front end popping noise?
2002 CHEVROLET CAVALIER
92,000 MILES • 4 CYL • FWD • AUTOMATIC
JONES215
everytime turn the wheel, hit a bump, or hit the brakes even, theirs a popping noise in the front ends.sounds as if the tires are loose..I changed the hub and wheel bearing on the drivers side front, but still the problem persists..any suggestions
Nov 9, 2009 at 12:27 PM
RHALL77
  • 3,361 POSTS
check your sway bar links and make sure there isnt one broken. Did you check your ball joints also?
Nov 10, 2009 at 11:12 AM
