My flasher and blinkers stopped working we bought the flasher fuse but we can't find where it is to replace it. Can you help
May 4, 2010 at 9:26 AM
BLUELIGHTNIN6
✓Experienced Mechanic
The flasher sits above the gas pedal behind a small, black panel . The panel is held on with one star bolt and is situated between the gas pedal arm and the bottom of the plastic molding that sits below the steering column. the flasher should be green and clipped to a small, cube shaped harness and attached to the inside wall by two plastic clips
May 4, 2010 at 9:43 AM
CRUMMIE
MEMBER
We fouund it and used replacement part (not green) but flashers and blinkers still not working any ideas?
May 4, 2010 at 10:02 AM
BLUELIGHTNIN6
have you checked the actual fuse or just the flasher relay?
May 4, 2010 at 10:59 AM
CRUMMIE
MEMBER
Checked Nd changed alll light bulbs still nothing
May 4, 2010 at 11:19 AM
BLUELIGHTNIN6
if bulbs, fuse and flasher are all good then must be wiring or faulty turn signal switch
