2002 Chevy Cavalier fault codes
95,000 MILES • 4 CYL • FWD • AUTOMATIC
ROADRUNNER118
  • 14 POSTS
How can I erase the fault codes so the indictors go off in the dash without using a code reader. I have done some repaire and service and have disconnected the battery for a couple minutes but I still have the SERVICE,ABS,and TC lights on. can they be erased to see if problem was corrected?
Oct 24, 2009 at 4:07 AM
MMPRINCE4000
  • 8,548 POSTS
You can go to some autoparts stores and have "P" codes erased. ABS codes are "C" codes and you would have to get them erased at a shop with a chassis scanner.
Oct 25, 2009 at 1:21 AM
