2002 Chevy Cavalier Engine Over heats
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
JRSKINNER84
I noticed a coolant leak a week or so ago it was driveable as long as you kept the coolant level filled. I have sence replaced the leaking water pump and the thermostat. But the car still gets to the red line of over heating once i start to move the car. As soon as I stop the temp drops a notch every minuet or two I don't know what else it could be looking for a little insite thank you for your help
Oct 5, 2008 at 10:28 AM
RHALL77
  • 3,361 POSTS
did you do the work or someone else. did they bleed the cooling system completely
Oct 6, 2008 at 1:31 AM
