2002 Chevy Cavalier changing the coolant
2002 CHEVROLET CAVALIER
52,000 MILES • 4 CYL • 2WD • AUTOMATIC
GERALDMELENDEZ
I wanted to change the coolant on my sisters' car, is the valve, to flush existing coolant, on the front right of the radiator? Also, do I need a special tool to torn it? if so, where can I get this.
Thanks
Oct 9, 2008 at 8:10 AM
BLACKOP555
  • 10,386 POSTS
you talking drain the old coolant or something to hook a hose up to to flush the system?
take a picture if possible...
usually to drain it i woudl disconnect lower and upper radiator hose and flush right through them. or youc an put in a flush t and disconnect a line somewherelse and flush it. i remove the thermostat so it flushes block and all.
Oct 9, 2008 at 10:54 AM
