2002 Chevy Cavalier
JUGGALO623
  • 2002 CHEVROLET CAVALIER
Transmission problem
2002 Chevy Cavalier 4 cyl Front Wheel Drive
the first few gears are getting hard to shift into what could that be?
Wednesday, October 22nd, 2008 AT 12:01 PM
MMPRINCE4000
  • 8,548 POSTS
Could be the clutch hydraulic system. Check clutch MC fluid level, if low you may have a leak in the system. You would have to inspect the system for leaks.
If full, then bleed the slave cylinder. Have someone push in clutch pedal, observe slave rod, movement should be smooth and about 1".
If hydraulic system checks out, then the clutch may be worn out and would need to be replaced.
Thursday, October 23rd, 2008 AT 7:17 AM
