2002 Cavalier, NO CHECK ENGINE
DRSTOVETOP
2002 Cavalier, 77000 miles, Standard Shift, 2.2L Most Basic Engine
Three weeks ago my car, after warming up, would not accelerate right away, it would not do anything for a second and then jerk forward and go. After talking to the Auto parts store, they said it was a the fuel filter that needed to be replaced (and now the fuel lines too because it rusted to the filter, thanks GM, good quality parts). No check engine lights come on ever. When this problem starts to occur, which is sporratic at best, it will stall when i come to a stop light and and come to a rest with the clutch pressed in. It will only do it once per driving period, the rest of the time, the engine will rev when im pressing the clutch from 8-900 to 16-1800 and bounce up and down until it calms down to normal idle around 8-900. Again, no check engine light comes on. I am vigilant about adding injector cleaner every 4000 miles when i change the oil (which is fully synthetic, not a problem is it?).
Is this an accurate assesment of the problem?
2nd...how do i get the green plastic clip off of the fuel filter, my first attempt nearly broke the clip off. Someone told me there was a tool that i needed.
Jan 23, 2007 at 4:23 AM
FRANK3969
  • 6 POSTS
Always keep a bottle of WD-40 around to spray the rusted area with or you can soak a rag in coca-cola and then put it around the area that is rusted to the fuel filter. Coke will eat away the rust. After appling the WD-40 try working the nuts loose from the fuel filter. Be sure to remove the Fuel pump Fuse first this way don't spill gas when you finally get the filter off. Also, when was the last time your spark plugs and wires were replaced? And for the green plastic clip I'm not really sure, but you might ask your local parts store if it's a special tool needed to remove it.
- Frank
Best Of Luck
Mar 1, 2007 at 1:01 AM
