2002 cavalier high idle
MBONGERS2
  • 8 POSTS
I have a 2002 cavalier z24, 5spd with 75,000 miles. It is idleing between 1500 and 2000 rpm. Replaced IAC,MAP and air charge temp sensor. No luck read your form about same problem and it stated MAF sensor or AIS sensor was posible fault. The 2.4 does not use a MAF sensor and I can not find the AIS sensor. If I pull the pintel out on the IAC the car with idle fine till I restart it. Any help would be great.
May 13, 2007 at 8:46 AM
MBONGERS2
  • 8 POSTS
I was unable to find problem with tools I had. Broght it to a dealer with the correct scan tools and they found it was the tps sensor was 2% that was bringing the idle up. They adjusted it, how I don't know but it is running good for know.
May 25, 2007 at 2:27 PM
