2001 Chevy Cavalier Will not start
160,000 MILES • 4 CYL • FWD • AUTOMATIC
PAUL WEEDEN
2001 Cavalier LS, 160,000 Miles 2.2L Engine.
On my way home today the engine stalled out. I put it in Neutral and tried to turn it over and it would not start I coasted into my driveway. There is a clunking sound coming from the front of the car by the belt when the engine turns over.
Does this sound like a broken my timing belt? and how much of a project is this to fix?
May 16, 2010 at 12:35 PM
  • 75,988 POSTS
Open the valve cover and crank the engine over are the valve opening and closing if so the belt is still intact but could have jumped if not do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 16, 2010 at 5:24 PM
