2001 Chevy Cavalier transmission or axles
14,000 MILES • 4 CYL • FWD • AUTOMATIC
GRATCHIC2
I was driving my 01 cavalier up a hill and without warning it stopped moving.. it felt as if i had knocked it into neutral there was no warning, no hesitation, after i got it towed home i jacked it up and took off the front tires, i can see the passenger side rotor moving very slowly in reverse but no other movement.. it will hold in park.. no engine lights on transmission fluid is good and i changed the lines going to the radiator thinking that may have been the problem.. which wasnt the case.. any thoughts?? im hearing check the front axles or that the transmission is gone..
Mar 22, 2010 at 4:22 PM
RHALL77
  • 3,361 POSTS
i would say tow it to a transmission shop. sounds like the trans to me.
Mar 23, 2010 at 8:19 AM
