2001 Chevy Cavalier sterring box
DAVID WEIMER
Steering problem
2001 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
There is a plastic piece on the side of the power sterring fluid box which has the rubber hose going to it the plastic piece snaped in to the hose how would i repair that do i have to get a whole new power stering fluid box... How would i fix this problem
Jun 6, 2009 at 3:45 AM
BILLYMAC
  • 2,204 POSTS
Hi sounds like maybe you have broken the return off in the power pump tank. if this is the case you need a new pump or atleast a new tank. if i understand your question. billymac
Jun 7, 2009 at 2:10 AM
