2001 Chevy Cavalier runs rough
2001 CHEVROLET CAVALIER
SDSMITH
Engine Mechanical problem
2001 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 120K miles
car is missing, check engine light is on TRAC off is now showing , so we changed both coil packs, plugs & wires, still doing the same thing...any idea what to do now....? it's 2.2 litre engine
Jun 12, 2009 at 10:45 AM
Scan the computer for codes this is your starting point
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jun 12, 2009 at 10:58 AM
