2001 Chevy Cavalier RADIATOR CLEANING
MICHAEL35
Engine Cooling problem
2001 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
HOW CAN I CLEAN OUT MY CLOGGED UP RADIATOR AT HOME WITH LITTLE OR NO MONEY ?
May 29, 2010 at 1:51 AM
  • 31,937 POSTS
Hi there,
This must be done by a radiator shop as the tanks must be removed to physically clean inside the cores, if it is at all blocked, using a chemical cleaner will only make it worse.
mark (mhpautos)
May 29, 2010 at 1:54 AM
MICHAEL35
if not chemicals then what do they use and what do you mean by tanks also thankyou for the help. i would donate but im tapped due to this ongoing car troubles.
May 29, 2010 at 3:06 AM
  • 31,937 POSTS
Hi there, Radiators have top & bottom tanks, this is where the hoses go, these are crimped or soldered to the core, the core is made up of many tubes or core tubes, these tubes need to be cleaned and often a probe is need to be passed through each tube first to break up the sludge and scale causing the blockage.
https://images.2carpros.com/forum/automotive_pictures/61395_Capture_6.jpg
Mark (mhpautos)
May 29, 2010 at 12:36 PM
