2001 Chevy Cavalier power window
2001 CHEVROLET CAVALIER
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
DENLEEP
my power window is down and i believe off track and will not go back up.drivers front already have door panel off and plastic pulled back but how do i get the window up manually? thank you for your time
Oct 31, 2009 at 2:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you will have to remove the window motor then force the window up. once the window is up you'll have to prop it up with some wood or something, since once you let go it will fall back down.
Oct 31, 2009 at 3:20 PM
