2 months ago the car overheat. Found the thermostat stuck closed. Car has been running fine since. Change oil, Spark plugs and wires, air filter. Started to drive car out of town. Temp was fine at 40 mph, at 75 mph would heat up to about 210. Brought car back to garage and leaked anti freeze. Found lower radiator hose with small hole in it. Replaced hose and water pump and thermostat. Car is still overheating no just when in the driveway. When they change 1st thermostat the used regular anti freeze. What could be causing to overheat? It acts like it is not circulating the coolant
Nov 9, 2010 at 3:19 AM
