Hi, i have a 2001 chevy cavalier 117000 miles/automatic... My problem is when i go to make a left turn from a starting at a stopped position, my car will sometimes start revving high halfway through the turn as if it was in the neutral position and then it will catch the gear i guess? and i will be able to move again. This only happens when i make a left turn and it only seems to do it when the transmission is switching gears. If i were driving stick, it almost seems like i would be making a left and halfway through the turn i would press down on the clutch pedal, give it also of gas and then release the clutch. Sometimes it happens so i hard i get some wheel spin out of it. My guess was maybe something with the transmission, maybe the differential considering it is on that side? Please help!
Nov 2, 2008 at 8:39 AM
