2001 Chevy Cavalier Horrible squeaking noise
77,362 MILES • 4 CYL • 2WD • AUTOMATIC
WATDOG32
I have been hearing a very high pitched squeaking from my front driver's side wheel area any time I steer towards the left (even slighty). It sounds like really bad brakes but it is not the brakes. It never happens when I am braking, just when I'm driving and steering towards the left.
Jun 27, 2008 at 12:46 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like either the backing plate is rubbing against the rotor or the brake sensor is hitting the rotor.
Jun 27, 2008 at 1:19 PM
SMOKINGALLOWED
  • 12 POSTS
There is some movement going on in there.Put some anti-squeel compound on the back side of your brake pads.It is kind of a glue that holds the pads away from the rotor.But examine it ALL for places that have been rubbing together, while you are in there.
Jul 1, 2008 at 2:51 PM
