2001 Chevy Cavalier headlights
86,500 MILES • 4 CYL • 2WD • AUTOMATIC
FREDD6113
daytime running lights and low beams will not turn on.Have changed the switch on the steering column, the headlight bulbs,and the relay switch in the fuse box...still will not turn on, only have highbeams. HELP!! I'm out of answers.
Feb 26, 2010 at 9:16 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated Check the fog lamp fuse in the instrument panel fuse box .. this controls DRL relay/low beams and fog light's
https://images.2carpros.com/forum/automotive_pictures/266999_cav_1.jpg
hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1008.png
Feb 26, 2010 at 12:21 PM
FREDD6113
"fredd6113"]Electrical problem
2001 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 87000 miles
daytime running lights and low beams will not turn on.Have changed the switch on the steering column, the headlight bulbs,and the relay switch in the fuse box and checked the fog fuse as well...checked every fuse and still will not turn on, only have highbeams. HELP!! I'm out of answers.
Mar 5, 2010 at 3:12 AM
DAVE H
  • 13,383 POSTS
Hey. Check the wiring/junction/connector behind the driver side headlight ... check for damage/wear/good connection repair any faults and recheck DRL function NOTE:- this wiring harness connector has other wires, not just the blue shown on diagram !!
https://images.2carpros.com/forum/automotive_pictures/266999_cav_2.jpg
hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1034.png
Mar 5, 2010 at 8:39 PM
