2001 Chevy Cavalier fuel pump problem?
107,000 MILES • 4 CYL • FWD • MANUAL
NICDGAF2316
I recently ran out of gas when i had about an eighth of a tank...i later put about 4 gallons of gas and i got no response. I unhooked the fuel line at the fuel filter and tried to start the car, nothing came out of the line, Also when i turned the key over to on i could hear the pump turn on,like a humming sound for a couple of seconds. i believe the relay fuse is fine. 2 weeks before this happened i changed the fuel filter and it ran fine. one last thing is, i noticed that my car was idling a little on the rough side before this happened this is unusual...fuel pump has never been changed.
Mar 4, 2008 at 2:16 PM
  • 75,988 POSTS
If you can hear the fuel pump for 2secs when key is at run and disconnecting the fuel filter not a drop -Replace the fuel pump.
Mar 4, 2008 at 2:21 PM
