Is there a fuel pump safety swith? If so where is it located?
Jan 1, 2010 at 11:52 AM
JDL
✓Experienced Mechanic
welcome to the forum, no safety switch, that I'm aware of. Use a gage and check fuel pressure. There is a fuel pump relay in the under hood fuse box. Can't say the relay is faulty, I'd have to check the relay circuits. Also, if you have passlock security system, that is a fuel injector disable system.
