2001 Chevy Cavalier FAN WONT TURN, CAR RUNNING HOT
19,000 MILES • 4 CYL • FWD • AUTOMATIC
INGRAM.1
DO NOT HAVE A DONATION AT THIS, THANKS
Jan 11, 2009 at 12:36 AM
BILLYMAC
  • 2,204 POSTS
hi billymac here..a temp switch and a fan relay turns this fan on.the temp switch is on the thermostat houseing follow the upper radiator hose down to the engine.with the engine running unplug this sensor does the fan come on.if yes sensor is bad or connector.if no relay or fan motor is bad usually it is the sensor...billymac
Jan 11, 2009 at 12:48 PM
