2001 Chevy Cavalier Engine revving while driving
NOSBIC
  • 2001 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 211,000 MILES
Our Cavalier has an annoying habit of revving up from roughly 2000-3000 rpm, usually when travelling at 50-100 kph. Sometimes it will rev and drop back right away, sometimes it will rev up and down 2-3 times in a row and sometimes rev up and hold it there for a few seconds. To me it seems like it wants to change to the next gear up but "can't decide" what it wants to do. Usually this will appear for a week or two, and then go away for awhile. Dealer thinks it is some valve that is sticky. Sorry, I can't remember exactly what valve he mentioned.
And to top it off, today the brake lights refused to turn off, even when the car is off. I had to pull the fuse to get them to go out. The switch on the brake pedal seems to move freely but is a little loose in its mounting bracket.
Any help/ideas would be fantastic!
Thursday, May 27th, 2010 AT 6:12 PM
MMPRINCE4000
  • 8,548 POSTS
He is probaly talking about IAC ( idle air control valve),
or a shift solenoid valve.
The brake switch has most likely worked loose, and causing problem, check bracket switch mounts on. These can be adjusted.
Friday, May 28th, 2010 AT 8:06 AM
