2001 Chevy Cavalier engin idle
45,000 MILES • 4 CYL • FWD • AUTOMATIC
KEN STEIN
engin starts at 2000 plus rpm and idles at 1000 rpm. if the problem is the iac valve what is the difficultly of installation or cleaning this unit?
Nov 8, 2008 at 3:13 AM
MMPRINCE4000
  • 8,548 POSTS
You more than likely have a vacuum leak, but remove the IAC and clean the pintle and base.
IAC is on the throttle body, remove bolts/connector, pull IAC out. Make sure you disconnect the negative battery cable before starting.
Nov 9, 2008 at 12:28 AM
