starter turns the engine over and the engine engages for 1 to 2 seconds and then dies
JDNELSON
When starting, the starter turns the engine over and the engine engages for 1 to 2 seconds and then dies. We had the battery replaced and started fine - for about two weeks. Then the car would do the same thing - starter turns the engine over and the engine engages for 1 to 2 seconds and then dies. We replaced some wire going to the module and started fine for about two weeks. We replaced the entire module (with a used one) and started fine - for about two weeks. We replaced the key cylinder and the same result - worked for two weeks. We replaced an (I believe) ignition switch and the same result - worked for two weeks. Any thoughts? Thank you for your time and input...greatly appreciated!
Feb 24, 2009 at 3:42 AM
KHLOW2008
  • 41,812 POSTS
The problem seems to be an intermittent power supply interruption and the circuit is from the BATT 1 Fuse (40A) underhood. Check for poor contacts of fuse and wire harness connectors under fuse box. Look out for signs of overheating.
https://images.2carpros.com/forum/automotive_pictures/192750_FuseBox01Cavalier_1.jpg
Jun 16, 2021 at 8:37 AM
