Hyd clutch pedel went to the floor and didn't come backup.No noise just went went to floor.
Feb 6, 2008 at 12:07 PM
MASTERTECHTIM
✓Experienced Mechanic
did you check the clutch master cylinder for fluid level? usually a small leak in the clutch slave cylinder is what causes the loss of fluid, you can normally fill up the reservoir and slowly pump the pedal to regain clutch operation.. hope this helps
