2001 Chevy Cavalier Clutch pedel went to the floor and stuc
GMETO
  • 2001 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • MANUAL
  • 80,000 MILES
Hyd clutch pedel went to the floor and didn't come backup. No noise just went went to floor.
Wednesday, February 6th, 2008 AT 8:07 PM
MASTERTECHTIM
  • 4,750 POSTS
Did you check the clutch master cylinder for fluid level? Usually a small leak in the clutch slave cylinder is what causes the loss of fluid, you can normally fill up the reservoir and slowly pump the pedal to regain clutch operation. Hope this helps
Wednesday, February 6th, 2008 AT 8:35 PM
