2001 Chevy Cavalier Check Engine Lite Code PO113
89,300 MILES • 4 CYL • FWD • MANUAL
KIDD037
My check engine light comes on once in while and when I had it read it came up a code PO113, which is "Intake Air Temperature Sensor 1 Circuit high Input", where is this located and can I fix this on my own?
Sep 15, 2009 at 2:36 AM
MMPRINCE4000
  • 8,548 POSTS
It is generally in the air cleaner box, before the MAF and throttle body, or air tube to air cleaner.
It is a small 2 prong connector, and measures the temp. of the incoming air to engine.
If air filter was recently changed, it may have not been reconnected correctly.
Sep 15, 2009 at 2:54 AM
