2001 Chevy Cavalier 'Check Engine Light' on
13,500 MILES • 6 CYL • FWD • AUTOMATIC
DKEHRES
When leaving work tonight, my left front headlight was out. Both high beams work. I drive about 5 miles to home, making a few stops for groceries, etc. When I pulled down my street, I put on low beams and heard a fast clicking. Then, the 'check engine light' came on. I parked in my driveway, turned off the engine and the lights. When I re-started my car, the 'check engine light' did not come back on.
I just had this car lubed and oil changed with a reliable mechanic, who usually checks things out pretty well. Is the 'check engine light' likely due to the new headlight problem?
Jan 12, 2010 at 3:11 PM
ZUE
  • 76 POSTS
Check Engine light should not be related to the headlight issue. The headlight issue sounds like a relay could be going bad becuase of the clicking noise you heard.
Jan 12, 2010 at 3:36 PM
