2001 Chevy Cavalier Bearings don't want to get out!!!
147,000 MILES • 4 CYL • FWD • AUTOMATIC
MGPROD
I've been working to change the bearings system on the front wheel conductor side. I removed all the bolts (3 bolts holding the bearings system), and I can't remove the bearings, it'ts like it been weld there in the rust!!!! I tried many things:
with a hammer, a crowbar . . . It dosen't move a millimetre!!!!!
What can I do??????????
Sep 13, 2009 at 5:12 AM
DOCFIXIT
  • 18,828 POSTS
Hi Have you removed axle? see diagrams
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_124.jpg
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_35.jpg
Hope this helps Thanks for donate
Sep 13, 2009 at 7:43 AM
MGPROD
Do you mean the big Bolt in the center of the bearing Assembly? If it's that, yes! If not, how I remove the axle? Thanks
https://images.2carpros.com/forum/automotive_pictures/408751_bearings_cavalier_axle_1.jpg
Sep 14, 2009 at 3:43 AM
DOCFIXIT
  • 18,828 POSTS
With the tool in figure. Is axle free in hub ie. can you push it back easily?
Sep 14, 2009 at 4:07 AM
MGPROD
Yes I can push it back easily.
Sep 14, 2009 at 4:24 AM
DOCFIXIT
  • 18,828 POSTS
Well you may need to remove spindle and press out bearing or get the tool to pull out bearing
Sep 14, 2009 at 4:38 AM
MGPROD
Can You point me the spindle in one of the 3 pictures that I sent you, and how to remove it?
https://images.2carpros.com/forum/automotive_pictures/408751_whereisspindle1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/408751_whereisspindle2web_1.jpg
https://images.2carpros.com/forum/automotive_pictures/408751_whereisspindle3_1.jpg
Sep 14, 2009 at 5:05 AM
DOCFIXIT
  • 18,828 POSTS
It is the heavy metal piece that hub/bearing is in. Need to remove ball joint, tie rod and strut. May want to see if a parts house has tool and will rent to you.
Sep 14, 2009 at 5:16 AM
