2001 Chevy Cavalier Alternator Replacement
130,000 MILES • 4 CYL • FWD • MANUAL
PILGRIM
I have a squealling coming from under the hood and I think it is the alternator. Can you tell me how hard is to replace it? Not sure what all has to be taken off to get to it. Also how hard is it to get to the idler arm to reduce the belt tension?
Thanks
Jan 11, 2008 at 6:46 AM
MASTERTECHTIM
  • 4,750 POSTS
a squeak might be coming from your alternator but probably not a squeal. if it sounds like the belt is squealing then you might have a bad serpentine belt tensioner. what engine do you have. its the eigth letter of your v.i.n. number
Jan 11, 2008 at 6:49 AM
PILGRIM
The eigth letter is T
Is the belt tensioner hard to replace?
Jan 11, 2008 at 6:59 AM
MASTERTECHTIM
  • 4,750 POSTS
i just looked it up and it does look tricky. it shows removing the ac compressor because the tensioner is part of the bracket holding ac compressor. id advise bringing it to your local repair shop and have them diagnose the problem. i hope this helps.
Jan 11, 2008 at 7:05 AM
PILGRIM
what should I expect to pay for an alternator replacement or tensioner replacement job
Jan 11, 2008 at 7:27 AM
MASTERTECHTIM
  • 4,750 POSTS
im showing a dealer list price of $300 for alternator and .7 hours labor. you will probably be charged up to 2 hours labor to diagnose and replace alternator. * you could use aftermarket parts and pay less money. im not showing a price on tensioner, but the labor is about 2 hours just to replace tensioner. i hope this helps
Jan 11, 2008 at 7:32 AM
PILGRIM
thanks for your help
Jan 11, 2008 at 7:38 AM
