2001 Chevy Cavalier Alternator
169,000 MILES • 4 CYL • 2WD • AUTOMATIC
SMINSER
How to Replace the Alternator on a 2001 Chevy Cavalier? Actually, i have the alternator off,but when putting the new one. How do i make the belt loose enough to fit on the pulley on the Alternator?
Feb 3, 2010 at 5:36 AM
JDL
  • 16,098 POSTS
Hi, You have to release the tension on the tensioner. Maybe I'm missing the point? There should be a cavity in the tensioner, it may take a 3/8 drive in the cavity, then you pull on the tensioner, to release tension on the belt. The picture is from autozone. I'm not positive about the drive size?
https://images.2carpros.com/forum/automotive_pictures/170934_cavalier_tensioner_1.jpg
Feb 3, 2010 at 6:09 AM
