2001 Chevy Cavalier ABS light is on....
ORALIA1
Brakes problem
2001 Chevy Cavalier 4 cyl Wheel Drive Type unknown Automatic 78000 miles
If your ABS light is on, would that have anything to do with you fuel pump? or the sensor?
Mar 4, 2008 at 1:57 AM
ED ARMES
  • 129 POSTS
Should not have anything to do with the fuel pump.
However if a speed sensor is at fault it could send messages to the computer that could affect the running of the vehicl such as fuel mixtures and transmission operation. I recommend you check for any codes stored in the computer to determine if it is a speed sensor or the ABS unit itself acting up. You did not supply enough information about what is going on to do much more diagnosis. You may want to reply with mor info about what is happening.
Mar 4, 2008 at 2:11 AM
