When both lights are on it usually means, that you have a leak in your brake system somewhere. Check for leaks at the master cylinder, along your brake lines and calipers. If your Cavalier has brake drums then check underneath your brake drum as well.
SPONSORED LINKS
Friday, February 12th, 2010 AT 8:04 PM
