2000 Chevy Cavalier wont start
125,000 MILES • 4 CYL • FWD • AUTOMATIC
BANKERS
well first of all the car sits outside and its -25 out so its cold but i put a new battery in and it wont start it turns over and fires but just wont start i put new plugs in the one electroode was smashed and i put a jug of heet in just in case there was water in there but it just wont start
Jan 5, 2010 at 9:00 AM
  • 75,988 POSTS
Do below to determine if it's a fuel or spark problem:
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 5, 2010 at 2:46 PM
