2000 Chevy Cavalier Stalling
MIKAL2A
Engine Performance problem
2000 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
car will stall when stopping at stop light but will start right back up again. only happenes ever so offten does not do it all the time. Happenes like once a week. Engine light comes on and only get e vap code. have changeed gas cap and did not work but have not had time to trace other possible causes. can not figure out why it stalles only ever so offten and then start right back up. Engine does not seem to run rough either.
Sep 14, 2010 at 5:23 AM
  • 110,248 POSTS
Have you checked for vacuum leaks? Also, if the check engine light comes on, have you had the computer scanned? Also, what evap code are you getting?
Sep 14, 2010 at 1:05 PM
MIKAL2A
Yes have checked for vacuum leak cant seem to find any or any pin holes anywere. The evap code that comes up is PO 440 . I have replaced gas cap , checked fuel pump pressure, fule filter and lines all seem to be ok. Going down the list of possible causes. Have not done a complete computer scan though. Can reset and engine light will stay out for about 3 days then come back on. its like a needle in a hay stack i guess to find cause.
Sep 15, 2010 at 4:08 AM
  • 110,248 POSTS
It is like looking for a needle in a haystack. The code you got for the EVAP is a generic code that can mean just about anything. However, when there is a leak, such as a fuel cap, it will say large leak detected, small leak detected...
Everything sounds good which leads me to believe you may have a crank sensor going bad.
Sep 15, 2010 at 2:11 PM
