2000 Chevy Cavalier sputtering
20,000 MILES • 4 CYL • 2WD • MANUAL
SNM*BELIEVE
The cavalier sputters in cold weather at a constant speed. It does not do it n hot weather, only in cooler temps. Acceleration is fine but at a constant rate of speed it starts sputtering doesn't matter if its 25 miles per hour or 55 miles per hour.
Sep 18, 2010 at 5:29 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked fuel pump pressure?
Sep 18, 2010 at 3:04 PM
SNM*BELIEVE
No the check engine light hasn't came on. We replaced the fuel pump about a year ago or less and it started doing this after wards. How do you check the pressure? And should there have been something that needed reset after we changed it? Thanks
Sep 18, 2010 at 6:05 PM
  • 110,248 POSTS
Nothing to reset. Here is a how to for checking fuel pump pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Sep 19, 2010 at 11:07 PM
SNM*BELIEVE
Ok so I am going to check the fuel pressure. Where is the relay if that needs to be replaced?
Sep 20, 2010 at 2:43 AM
  • 110,248 POSTS
It is under the hood in the power distribution center.
Sep 20, 2010 at 6:31 PM
