1992 Chevy Cavalier Spitting and sputtering
140,915 MILES • 4 CYL • FWD • AUTOMATIC
GTRGILBERT541
  • 14 POSTS
the car ran perfect until about a month ago when it started spitting and sputtering. it will spit and sputter until you get about 60-65 miles and hour i think it has something to do with the electrical system with the transmission
Apr 22, 2008 at 10:26 AM
BMRFIXIT
  • 19,053 POSTS
i have to ask did you check it for tune up
Apr 22, 2008 at 1:07 PM
GTRGILBERT541
  • 14 POSTS
[quote:68c5a52f03="BMRFIXIT"]i have to ask did you check it for tune up[/quote:68c5a52f03]
i have given the car a minor tune up new spark plugs - wires, a new Egr valve, and lots of new sensors $$$ , i also rerun some old dry rotted wires it seems all i do is put money in the car but it is a good one when it does run
Apr 22, 2008 at 1:29 PM
BMRFIXIT
  • 19,053 POSTS
you need to check timing and catalytic converter
check fuel pressure
Apr 22, 2008 at 2:06 PM
GTRGILBERT541
  • 14 POSTS
[quote:688199b50f="BMRFIXIT"]you need to check timing and catalytic converter
check fuel pressure[/quote:688199b50f]
fixed it had something to do with the mapping sensor
Apr 23, 2008 at 3:16 PM
