2000 Chevy Cavalier Rear window defogger
WRENCHHEAD
  • 6 POSTS
Electrical problem
2000 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
Yes i've got a 200 Chev Cavalier and the rear window defogger does not work. Couldn't find a broken wire the light on the dash lights up but no window defoger any ideas
Dec 23, 2008 at 3:02 AM
RHALL77
  • 3,361 POSTS
use a test light and touch the terminal end of the grid and see if you have power. let me know what you find and ill give you a hand
Dec 23, 2008 at 8:33 AM
WRENCHHEAD
  • 6 POSTS
[quote:ce4c43c33a="rhall77"]use a test light and touch the terminal end of the grid and see if you have power. let me know what you find and ill give you a hand[/quote:ce4c43c33a] No power at all
Dec 23, 2008 at 8:55 AM
WRENCHHEAD
  • 6 POSTS
[quote:8f8a1e1c9a="wrenchhead"][quote:8f8a1e1c9a="rhall77"]use a test light and touch the terminal end of the grid and see if you have power. let me know what you find and ill give you a hand[/quote:8f8a1e1c9a] No power at all[/quote:8f8a1e1c9a]
Dec 23, 2008 at 9:12 AM
WRENCHHEAD
  • 6 POSTS
There is no power at the spade connector at the back window
Dec 23, 2008 at 9:16 AM
RHALL77
  • 3,361 POSTS
check and see if there is voltage at the other end of the switch when you turn it on. you may have a bad switch
Dec 23, 2008 at 1:08 PM
WRENCHHEAD
  • 6 POSTS
I replaced the switch and there is still no power any other suggestions
Dec 24, 2008 at 2:12 AM
RHALL77
  • 3,361 POSTS
did you check all the fuses just to be sure
Dec 26, 2008 at 2:09 AM
WRENCHHEAD
  • 6 POSTS
Yes checked all fuses there is power coming out of the switch but nothing going to the wire at the window
Dec 26, 2008 at 2:37 AM
RHALL77
  • 3,361 POSTS
then you need to start chasing wires and find the break in them.
Dec 26, 2008 at 5:58 AM
