2000 Chevy Cavalier OBD2 codes
96,000 MILES • 4 CYL • FWD • AUTOMATIC
FRANK WETZEL
My cavalier has the engine check light on. So, I used an OBD2 Autoscanner which gave a code of P0440
EVAP EMISSION. What's my next move?
Nov 14, 2009 at 10:08 AM
SERVICE WRITER
  • 9,123 POSTS
There are various causes for this code. What I would do first is to pull off the gas cap and get a look at the sea;lng area of the fuel filler neck. Make sure it is clean and the cap seal is not cracked. A little grease on the surface can help.
If you do this it will take a few days to clear the code and turn off the light. The fuel has to be between 1/4 and 3/4 full for the monitor to run it's self test.
Nov 14, 2009 at 10:15 AM
