2000 Chevrolet Cavalier Check Engine Light
MBSAEGERT
My car has 48, 000 miles (I know that it very low). My check engine light came on this morning while driving to work. It had happened one other time when I had filled up with gas. That is not the situation at this time. My trunk yesterday was not closing properly and had to be adjusted by moving the screws so it would close. Since it is always used with my automatic button and not with the key itself, do you think that this could be the cause since it is electrical also? My car when stopped at a light did not act any differently, idle or other idiot light-wise, so I am stumped.
Jul 25, 2007 at 11:44 PM
BRUCE HUNT
  • 3,754 POSTS
Drive it to an Autozone or go somewhere and have the code pulled. The warning light is just that, it is telling you that something is not working correctly and it will give us a pointer to know where to look for the problem. Don't ignore these lights.
Jul 26, 2007 at 12:53 AM
Suggested Repair
Have the check engine light diagnostic code read at an auto parts store or repair shop, then diagnose from that code. Do not ignore the warning light.
Conversation Summary
The owner of a 2000 Chevrolet Cavalier with 48,000 miles reported a check engine light that came on while driving. It had happened once before after refueling, but that was not the case this time. The trunk latch had been adjusted the day before, and the owner wondered whether that electrical issue could trigger the light. The car idled normally with no other warning lights. The expert advised having the diagnostic code pulled and not ignoring the warning.
